Safe
Boas pessoal ...
Aki á dias vinha a puxar um cadinho pela makina e quando ia a passar um pouco os 220 fez safe ....
fui ao vag-com ver os erros e apareçeu o seguinte
Address 01: Engine
Part No: 038 906 019 NJ
Component: 1,9l R4 EDC G400SG 7331
Coding: 00102
Shop #: WSC 06402
VSSZZZ6LZ7R090470 SEZ7Z0F3566718
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Coding: 0002338
Shop #: WSC 06402
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 71
Mileage: 26053 km
Time Indication: 0
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 26053 km
Time Indication: 0
Address 08: Auto HVAC
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Address 09: Cent. Elect.
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
49-10 - No Communications - Intermittent
Address 15: Airbags
Part No: 6Q0 909 605 AE
Component: 0G AIRBAG VW5 0C 0010
Coding: 12359
Shop #: WSC 06402
Address 17: Instruments
Part No: 6L0 920 823 H
Component: KOMBIINSTRUMENT VDO V01
Coding: 00105
Shop #: WSC 00000
1 Fault Found:
Address 19: CAN Gateway
Part No: 6N0 909 901
Component: 0068 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Fault Found:
Address 44: Steering Assist
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10131
Shop #: WSC 06402
1 Fault Found:
Address 46: Central Conv.
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00017
Shop #: WSC 06402
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
Alguem pode dar uma ideia do que seja ????
