Problemas 6L 130cv
sniperboy
Utilizador Banido
Boa noites,
Adquiri recentemente um ibiza 1.9tdi sport de 130cv, e detectei alguns problemas , penso que sejam simples, assim espero!!!
o que detecto é:
-ponteiro do combustivel não mexe.
-ligo o carro e depois de uns 30s a trabalhar acende a luz da temperatura e fica a piscar, o que e certo e que verifico a agua e o nivel ta normal, e o ponteiro nao sobe acima dos 90.
Desde ja obrigado pela ajuda!!!!
ja posto fotos da fera!!!!
Tenho vag-com e detectou alguns erros:
Tuesday,19,July,2011,18:45:11:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ3R027526 Mileage: 129390km/80399miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 DQ
Component: 1,9l R4 EDC 0000SG 1536
Coding: 00002
Shop #: WSC 06402
VCID: 69D2A1203905
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 06403
VCID: 4280568C64F3
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 244CF0149EA7
2 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
000 - - - Intermittent
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
VCID: 3B7E2B680319
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 S
Component: 06 AIRBAG VW5 02 0007
Coding: 22838
Shop #: WSC 06441
VCID: 479647984FD1
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 830 K
Component: KOMBI+WEGFAHRSP TRW V01
Coding: 00145
Shop #: WSC 06402
VCID: 336E03482B49
VSSZZZ6LZ3R027526 SEZAZ0B1540112
2 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
00779 - Outside Air Temp Sensor (G17)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 61 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID: F0E44C449ADF
Address 25: Immobilizer Labels: None
Part No: BITTE ADRESS
Component: E 17 EINGEBEN
VCID: 3A702E6C0C23
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00121
Shop #: WSC 06402
VCID: 397231600925
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 5p Komfortgerát 0001
Coding: 00259
Shop #: WSC 06402
VCID: 3D7A25701D0D
Part No: 6Q2959802A
Component: 5p Tõrsteuer.FS KLO 0001
Part No: 6Q2959801A
Component: 5p Tõrsteuer.BF KLO 0001
Part No: 6Q0959811A
Component: 5p Tõrsteuer.HL KLO 0001
Part No: 6Q0959812A
Component: 5p Tõrsteuer.HR KLO 0001
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
27-10 - Implausible Signal - Intermittent
End ---------------------------------------------------------------------
sera k compensa????
axo k a luz vermelha da temperatura vai continuar a picar....
ha smp a opçao d meter o de apenas 4 manometros.
cmp
O meu teve os mesmos sintomas, tentei repara-lo mas acabei por estragar ainda mais. Resultado foram uns manometros novos.... Desejo-te sorte!
o meu reforçei as soldasd da fixa verde e fikou ok ;-)....embora o ponteiro da gota n funcione, pois uma micro resistencia que tem nas pistas do ponteiro da gota foi á vida...e se calhar mais algo que passe por essa pista...mas de resto funciona td mt bem cm sp...
Entao em primeiro lugar vou desmontar o quadrante e verificar as soldas....
Alguem podia dar umas dicas como desmontar, e que nunca desmontei neste modelo!!!!
O meu ponteiro do combustivel tbm de vez em quando não funcionava...
Os sintomas são tal e qual o meu manometro...
É so refazer soldaduras...
Entre trabalho e dor de cabeca por experiencia propria, compensa muito mais meter quadrante usado de 4 manometros. paguei 100e por um fr numa sucata.
podes mandar reparar o quadrante, aconteceu tal e qual com o meu... :)
Olá amigo Rosado...
O meu também está nesse estado. Podes-me dizer onde o mandaste reparar?
Já refiz as soldaduras e até ficou bom por uns tempos mas já voltou a pifar... Akilo é algo mais que soldaduras, acredito que seja algum micro componente que akilo tem por lá...
Desde ja obrigado pelas respostas.....
Vou desmontar o quadrante, alguem me pode explicar como desmontar?
Outra questao, onde esta localizado o sensor de temperatura, tanto do motor e tambem da temperatura que faz na rua?
cumprimentos
cumprimentos
o da temp ambiente esta perto do farol nevoeiro dir. o da temp da agua esta por baixo da bomba de pressao de gasoleo
