[PROBLEMA] Erros no Vagcom...
MiguelTavares
S.T.A.F.F.
Seat Ibiza 6L 1.4TDI Ecomotive - DPF (out)
Code:
012296 - Camshaft Position Sensor (G40): Signal Out of Range
               P3008 - 000 -  -  - Intermittent
             Freeze Frame
                    Fault Status: 00110000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Mileage: 33400 km
                    Time Indication: 0
             Freeze Frame
                    RPM: 4641 /min
                    (no units): 3.0
                    Load: 100.0 %
                    Voltage: 14.06 V
                    Temperature: 66.6°C
                    Idle Stabilization: 57.1°KW
000833 - Camshaft Position Sensor (G40): Implausible Signal
               P0341 - 000 -  -  - Intermittent
             Freeze Frame
                    Fault Priority: 3
                    Fault Frequency: 1
                    Mileage: 33400 km
                    Time Indication: 0
             Freeze Frame
                    RPM: 4788 /min
                    (no units): 3.0
                    Load: 100.0 %
                    Voltage: 14.14 V
                    Temperature: 66.6°C
008597 - Oxygen (Lambda) Sensor B1 S1: Signal too Low (Lean)
               P2195 - 000 -  -  - Intermittent
             Freeze Frame
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 34053 km
                    Time Indication: 0
             Freeze Frame
                    RPM: 1596 /min
                    Speed: 39.0 km/h
                    (no units): 38.0
                    Temperature: 27.9°C
                    Absolute Pres.: 346.8 mbar
                    Voltage: 1.168 V
                    (no units): 0.03
Alguém me ajuda nestes erros?
