Ibiza 6k2 luz esp, abs e travao de mao
Boa noite malta,
Tenho um Ibiza 6k2 que acende primeiro as luz de esp e dps passodos alguns/mts (conforme) acende a luz de abs e a luz do travão de mao fica a piscar. Já li com vag-com mas precisava de uma ajudinha.
VCDS Version: Release 11.11.2
Data version: 20120126
Wednesday,24,September,2014,20:22:53:55062
Chassis Type: 6K - Seat Ibiza/Cordoba
Scan: 01 02 03 08 15 17 25 45 56
Mileage: 316960km/196949miles
Address 01: Engine Labels: None
Part No: 038 906 018 FB
Component: 1,9l R4 EDC 0000SG 2170
Coding: 00005
Shop #: WSC 06401
VCID: 5BBE2006C93EA1B
2 Faults Found
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17656 - Start of Injection Timing Regulation
P1248 - 35-10 - Control Deviation - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
VCID: 75EA56BE4FDA17B
2 Faults Found
65535 - Internal Control Module Memory Error
00-00 - -
00668 - Supply Voltage Terminal 30
16-00 - Signal Outside Specifications
Address 08: Auto HVAC Labels: 6K0-959-291.lbl
Part No: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
VCID: F4ECEBBAC4A08E3
No fault code found.
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
VCID: ECDCF3DA9C90563
Address 17: Instruments Labels: 6K0-920-xxx-17.lbl
Part No: 6K0 920 801 F
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00142
Shop #: WSC 48132
VCID: 2B5EB0C6D91E11B
Subsystem 1 - Part No: IMMO
Component: IDENTNR: SEZ7Z0Y0832782
IMMO-IDENTNR: SEZ7Z0Y0832782
Address 45: Inter. Monitor Labels: Redir Fail!
Part No: 6N0 951 171 C
Component: Innenraumueberw. 0003
VCID: 2F66A4D6ED066DB
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
2 Faults Found
00853 - Loudspeaker(s); Rear
36-00 - Open Circuit
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End ---------------------------------------------------------------------
Desde já muito obrigado
ve os fusiveis se ainda nao o fizeste,e toma especial atançao nos k estao na bateria pk costumam ficar em mau contacto em vez de queimarem..
Já vi isso tudo e continua na mesma e com vag-com tenho aqueles 2 erros, mais alguém com mais alguma dica?
Cumprimentos,
Hugo Silva
Cumprimentos,
Hugo Silva
Eu tenho o mm problema há bué! Lol a fixa ou o fio foi a vida! O meu partiu o fio xD Confirma as rodas
Sent from my Nexus 4 using Tapatalk 2
