erros vag-com
Viva PPL tudo em altas? Espero que sim...
A carrinha (Passat 1.6 gasolina) do meu sogro apresentou os seguintes erros:
Chassis Type: 31 - VW Passat B3
Scan: 01,02,03,08,15
Controller: 3B0 907 557 C
Component: 1,6l R4/2V SIMOS HS D03
Coding: 04001
Shop #: WSC 05311
2 Faults Found:
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
31-10 - Open or Short to Ground - Intermittent
00282 - Throttle Position Actuator (V60)
44-10 - Short Circuit - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 B
Component: CLIMATRONIC V 1.0.0
Coding: 05000
Shop #: WSC 05311
3 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
01206 - Signal for Duration of Ignition: OFF
35-00 - -
00281 - Vehicle Speed Sensor (G68)
35-10 - - - Intermittent
Skipping Address 15-Airbags
End -------------------------------------------------------
Podem dizer-me o que são estes erros?
CUMPS...
