Erros Vag-com
Boas povo, fiz recentemente um teste no vag, para verificar os erros, e deparei-me com vários.
Se algum entendido me puder fazer o favor de explicar o que são, e como resolver, sou lhe grato.
Deixo aqui os resultados:
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 DQ
Component: 1,9l R4 EDC 0000SG 1536
Coding: 00002
Shop #: WSC 06402
VCID: 69DDB9971362FD6
1 Fault Found
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 06403
VCID: 428F4E3B4E94CEE
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 2443E8A3E4C0E0E
3 Faults Found
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
VCID: 3B7133DF297EBF6
Note: Excessive Comm Errors
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 S
Component: 14 AIRBAG VW5 07 0007
Coding: 12596
Shop #: WSC 06441
VCID: 47995F2F65B6EB6
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 830 K
Component: KOMBI+WEGFAHRSP TRW V01
Coding: 00145
Shop #: WSC 06402
VCID: 33611BFF012E776
VSSZZZ6LZ3R141385 SEZAZ0B3370149
1 Fault Found
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID: F0EB54F3B0B88CE
Address 25: Immobilizer Labels: None
Part No: BITTE ADRESS
Component: E 17 EINGEBEN
VCID: 3A7F36DB264486E
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00121
Shop #: WSC 06402
VCID: 397D29D723428D6
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 2G Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
VCID: 3D753DC7376AB16
Subsystem 1 - Part No: 6Q2959802A
Component: 2G Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 6Q2959801A
Component: 2G Tõrsteuer.BF KLO 0001
Abraçada
Viva,
Limpaste os erros antes de fazer este log?
O que convem fazer é limpar todos os erros, conduzir o carro normalmente durante 1 ou 2 dias e depois ler novamente os erros.
Pode acontecer que alguns desses erros já sejam antigos e até já possam ter sido resolvidos.
Viva,
Boas, por acaso foi feito antes de limpar os erros. Mas lembro me que quando limpei, ele fez outro scan de seguida e só tinha desaparecido 1 acho. Se alguém puder ajudar a descobrir de onde provêm agradeço ;)
Sent from my GT-I9000 using Tapatalk 2
O mais grave por assim dizer é o que diz respeito à falta de comunicação entre o quadrante e a ECU.
Os do ar condicionado dizem respeito aos motores que seleccionam a direcção do ar.
Há muitos módulos que se queixam de erros de comunicação.
Cá para mim, tens 1 módulo que deve estar avariado e está a provocar toda a falha de comunicações, inclusivé entre o quadrante e a ECU.
esses que falas do a.c tb tenho uns problemas, penso ter o a.c descarregado, porque não faz ar frio nem ouço o motor a atracar..
os erros que falo:
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
2 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - -
os erros que falo:
2 Faults Found:
000 - -
THX, já tenho conhecimento de um erro então! O meu está descarregado sim.
O meu quadrante está todo marado, os erros derivados a ele não me surpreendem.
Mas dá para saber se algum dos erros que apresenta, é grave?
Abraço!
Abraço!
Tirando os erros do AC, só tens mais esse erro de comunicação entre a ECU e o quadrante e que supostamente também está a interferir com vários outros módulos.
Para mim, tal como já disse, grave é os módulos se queixarem de problemas de comunicação!
Olha aqui um resumo do teu log:
1 Fault Found
3 Faults Found
1 Fault Found
No Faults Found
Do total de 10 módulos, só 3 módulos é que dizem claramente que não têm erros: 3, 19 e 44.
A primeira coisa que pensei mal vi isto foi... MEU DEUS!
Tem mesmo muitos erros esse 6J.
Ora bem, tens que começar por um lado...
Verificar fichas se estão bem ligadas no quadrante e todos os arredores(ECU, motores de posicionamento, basicamente tudo que tenha erros)
Fusíveis se estão todos em ordem ;)
E se tiveres hipótese ir trocando as peças e verificar se os erros vão desaparecendo ;)
