EGT digital controller
O que acham disto?Parece ser bom?
Alguem que use destes manometros ou que perceba da situacao se poder dar o seu parecer agradecia pois estou a pensar em mandar vir...
Up for sale is a brand new compact size (1x2x3" or 24 x 48 x75mm) digital thermometer, pyrometer for Exhaust Gas Temperature (EGT) monitoring. It can be powered directly by the car battery (12 VDC). Its bright LED display is easy to read from a distance as compared with many dim LCD type digital thermometers. The programmable alarm will turn on a blue LED in the front panel to get driver's attention if the temperature is above the setting point. It will also close a relay output port that can be used to turn on a buzzard, shut off the fuel, or turn on a cooling fan. The meter stores the peak temperature with time that can be checked later. It can also operate in the peak holding mode so that only the maximum temperature is displayed. The meter will accept all EGT sensors on the market and display the temperature in either Celsius or Fahrenheit. The brightness of LED display can be synchronized with headlight. When the headlight is turned on in the night, the display will be dimmed by the illumination signal. It can also be dimmed directly from the key pad.
This auction also includes a clamp-on EGT sensor. It is a K type thermocouple sensor with exposed tip junction for fast response time. The probe diameter is 3/16", clamp range is 1.5-2.5". The insertion depth is adjustable with 0.85" maximum. Cable length, 78” (2 meters). Maximum working temperature: 1000C (1800F
Boas...
Sei q é um pouco chato o q tou a pedir, mas sera q não podias mandar vir uma cena dessas pa mim... Não tenho conta de ebay nem percebo nada desse tipo de compras :(
Se me poderes ajudar agradecia imenso...
Abraço :D
Viva.
Para quem tem o carro stock isto traz alguma vantagem?
stock como quem diz :rir: so cat e panela final off :finga:
Sim , é mais uns numeros para olhares e dizer "q bonito!" :rir:
Agora aserio , stock n serve de nd... fica mto longe de qq limite de EGTs.
Alterado vale a pena para se ter uma noçao de quando o turbo ja se esta a "fundir" [-o<
Egt
Boas
Alguém sabe o preço exacto do conjunto?
O do site acho que não traz o sensor!
No preço que coloquei aí, o sensor já está incluso.
"This auction also includes a EGT sensor. It is a K type thermocouple sensor with exposed tip junction for fast response time. The probe diameter is 3/16", Mounting thread is 1/8 NPT. The insertion depth is adjustable with 1.3" maximum. Cable length, 78” (2 meters). Maximum working temperature: 1000C (1800F)"
