Ajuda TEste Maf com VAG COM
Boas pessoal
outro dia fiz um teste a minha maf com o vag o carro é um 6k2 tdi90,
nao me correu la muito bem o teste pois começou a chover logo nesse minuto e nao deu pa puchar muito pelo carro o que eu queria saber e se alguem consegue entender os resultados q aki vou por.
038-906-019-DQ --- Engine
Component:1,9l R4 EDC G000SG 1536, Coding:00002
Saturday,21,November,2009,15:46:30:26365
VCDS Version: Release 805.0 Data version: 20080730
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,0 /min,RPM,0.0 mg/str,Inj. Quantity,-35.7°KW,Idle Stabilization,-20.7°C,Temperature,
2,0 /min,RPM,0.0 %,Load, 0 1 0,Bin. Bits,-20.7°C,Temperature,
3,0 /min,RPM,850.0 mg/str,Mass Air / Rev.,1249.5 mg/str,Mass Air / Rev.,4.8 %,Duty Cycle,
4,0 /min,RPM,39.4 °BTDC,Ign. Timing,-35.7°KW,Idle Stabilization,0.0°KW,Idle Stabilization,
5,0 /min,RPM,50.8 mg/str,Inj. Quantity,0.0,(no units),-21.6°C,Temperature,
6,0.0 km/h,Speed, 0 0 0,Bin. Bits,0.0 %,Load,0.0,(no units),
7,32.4°C,Temperature,0.0 %,Duty Cycle,25.2°C,Temperature,-22.5°C,Temperature,
8,0 /min,RPM,18.7 mg/str,Inj. Quantity,0.0 mg/str,Inj. Quantity,32.4 mg/str,Inj. Quantity,
9,0 /min,RPM,0.0 mg/str,Inj. Quantity, , ,0.0 mg/str,Inj. Quantity,
10,1249.5 mg/str,Mass Air / Rev.,999.6 mbar,Absolute Pres.,994.5,(no units),0.0 %,Load,
11,0 /min,RPM,193.8 mbar,Absolute Pres.,994.5,(no units),99.6 %,Duty Cycle,
12,01010000,Bin. Bits,8.01,(no units),12.46 V,Voltage,-21.6°C,Temperature,
13,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,0.00 mg/str,Inj. Quantity,
14, , , , , , , , ,
15,0 /min,RPM,0.0 mg/str,Inj. Quantity,0.00 l/h,Fuel Consump.,18.7 mg/str,Inj. Quantity,
16,17.2 %,Load,10011000,Bin. Bits, 00,Bin. Bits,12.46 V,Voltage,
17,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,00000000,Bin. Bits,
18,2.0,(no units),2.0,(no units),2.0,(no units),2.0,(no units),
19, , , , , , , , ,
20,0 /min,RPM,0.0 Nm,Torque,70.0 mg/str,Inj. Quantity,0.0 mg/str,Inj. Quantity,
21,0.0,(no units),10000000,Bin. Bits,00000100,Bin. Bits,00000100,Bin. Bits,
22,1.0,(no units), 000000,Bin. Bits,0.0,(no units),144.0,(no units),
23,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
24, , , , , , , , ,
25, , , , , , , , ,
26,03FFF1FF, ,
27,0 /min,RPM,0.0 km/h,Speed, , ,0.0 km/h,Speed,
28,0.0 %,Duty Cycle,0.0 %,Duty Cycle,0.00 bar,Pressure,10010000,Bin. Bits,
29, , , , , , , , ,
30, , , , , , , , ,
31, , , , , , , , ,
32, , , , , , , , ,
33, , , , , , , , ,
34, , , , , , , , ,
35,0 /min,RPM,0.0 %,Duty Cycle,32.4°C,Temperature,12.46 V,Voltage,
36, , , , , , , , ,
37, , , , , , , , ,
38, , , , , , , , ,
39, , , , , , , , ,
40, , , , , , , , ,
80, ??? ??.??.?? 39S00137 ???? ????,,
81, , , , , , , , ,
82, , , , , , , , ,
83, , , , , , , , ,
84, , , , , , , , ,
Conclusao depois de fui fazer um scan ao erros(engine)e apareceu-me esto
16485 - Can't Decode, CODE File Not Loaded!
P0101 - 35-10 - Can't Decode, CODE File Not Loaded! - Intermittent
Readiness: N/A
ALGUEM PODE AJUDAR EM PENSO QUE TENHO A MAF ESTRAGADA,so nao sei ler é os resultados q estao na folha de excel
