Boas
Aconteceu-me uma coisa estranha, de um momento para o outro a luz do airbag apareceu no painel e nunca mais apagou
Hoje, como tenho o cabo e Vag-com fiz um scan ao carro e os resultados foram os seguintes:
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller: 038 906 019 DQ
Component: 1,9l R4 EDC 0400SG 1536
Coding: 00002
Shop #: WSC 06402
VSSZZZ6LZ3R165139 SEZAZ0C0080081
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V20
Coding: 00188
Shop #: WSC 06403
Address 08 -------------------------------------------------------
Controller: 6L0 820 043
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
000 - - - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
3 Faults Found:
00511 - Selector Lever (E313)
49-00 - No Communications
00778 - Steering Angle Sensor (G85)
01324 - Control Module for All Wheel Drive (J492)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 830 K
Component: KOMBI+WEGFAHRSP TRW V02
Coding: 00145
Shop #: WSC 06402
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
3 Faults Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 2G Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
End -------------------------------------------------------
Apareceram alguns erros :redcard:
Alguem me pode ajudar de forma a apaga-los ou a explicar do que se trata?
Coding: 00002
Shop #: WSC 06402
Coding: 00188
Shop #: WSC 06403
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
Coding: 00140
Shop #: WSC 06402
3 Faults Found:
Coding: 00145
Shop #: WSC 06402
Coding: 00014
Shop #: WSC 06402
3 Faults Found:
Coding: 00121
Shop #: WSC 06402
Coding: 00064
Shop #: WSC 06402
